wardy18
Help Please, Ive Made A Mistake!
wardy18
im soo annoyed with myself..........
just rebuilding the engine in my mates 1900 8v XU9 i have forgotten to number the 4 Injector plugs when i removed them so dont know which ones to plug into which injectors :wacko::(:)
i know i know such a simple and silly mistake
how do i sort this out and find out which ones go where?!
unfortunately i need to know asap i need teh car running and out of the way
thanx in advance for your help
Stu
They're batch fired mate so you can put them on anyhow, you'll find they'll fit better some ways rather than others.
wardy18
ah brilliant, so they all fire at the same times?!
i suppose it all happens so fast its pretty much a constant flow.....
as long as ur sure they all fire at the same time and i can fit them wherever
thanx mate, such releif
Yep as said they will go on anyway and tend to only fit on the injector they came from now with the wires going hard with age, When they were new it was different as they where nice and flexi!!
wardy18
fine job
thats great, thought that was gonna get really complicated
looking forward to see how it goes as ive had 28 thou skimmed off the head while it was off, see what difference it makes to the drive
McPikie
erm, surely if they all firect at once this will be wasted fuel?
tom_m
it all ends up in the engine eventually :huh:
there are no significant differences in top end, wide open throttle, horsepower between batch fired and timed systems. We have also not seen any significant differences in fuel economy between the two strategies
from http://www.sdsefi.com/techseq.htm
