v6Max 0 Posted November 5, 2007 Quick question - I'm at work so can't check... What size socket is needed to undo the hub nut on a G plated 1.9 GTi (front) - any ideas? Any help greatly appreciated... Share this post Link to post Share on other sites
Anthony 1,003 Posted November 5, 2007 35mm usually, but some aftermarket driveshafts (GKN springs to mind) have 36mm hubnuts. Share this post Link to post Share on other sites
Rob_the_Sparky 10 Posted November 6, 2007 Note that you need a deep socket so you can get it on with the wheel attached... Share this post Link to post Share on other sites
v6Max 0 Posted November 6, 2007 Advice appreciated - wheels are off the car but I've sorted a deep socket out from Draper since it seems 35mm is not that common a size. Share this post Link to post Share on other sites
SamGTi 0 Posted November 6, 2007 v6Max said: Advice appreciated - wheels are off the car but I've sorted a deep socket out from Draper since it seems 35mm is not that common a size. Tell me about it! I ordered a deep impact 35mm socket which arrived the next day only to find out mine were 36mm! Share this post Link to post Share on other sites
