josh1990 0 Posted November 3, 2007 Just bought off ebay 1.0 1.1 1.4 center exhaust piece(http://cgi.ebay.co.uk/PEUGEOT-205-CENTRE-EXHAUST-PIPE-1-1-1-1-1-4-1992_W0QQitemZ160168996162QQihZ006QQcategoryZ10406QQrdZ1QQssPageNameZWD1VQQcmdZV ewItem), will it fit heard the 1.1 straight pipe will so i think this is the same. This exhaust piece is for a 205 Rallye 1360 Tu 8 valve 1992, just wondering what i will need for the job. clamps and seals and such, also do you think it will fit? Cheers Josh Share this post Link to post Share on other sites
trogboy 17 Posted November 5, 2007 The link doesn't work but all of the base TU 205 centre sections are pretty interchangable. You'll probably need WD40, a wire brush, some exhaust paste, a 10mm spanner plus a couple of 13mm spanners. Jobs dead easy really. Best of luck Share this post Link to post Share on other sites
josh1990 0 Posted November 5, 2007 trogboy said: The link doesn't work but all of the base TU 205 centre sections are pretty interchangable. You'll probably need WD40, a wire brush, some exhaust paste, a 10mm spanner plus a couple of 13mm spanners. Jobs dead easy really. Best of luck Ok thanks for that mate, Josh Share this post Link to post Share on other sites
josh1990 0 Posted November 11, 2007 Got it done today sounds alot better. Share this post Link to post Share on other sites
