Guest NickMiami
Quick Q About Offset Of Wheels....
Guest NickMiami
Does anyone know if ET34 would fit the 205 and if so what size spacers would i need.......
Arahan
As said (not by me) in the other thread about different wheels on 205's, standard offset is et18, so with an et34 i think spacers would definatly need to be used!
engine killer
sounds like a set of 16mm spacer is needed if your wheels are not very much wider than 6.5"
Guest NickMiami
Thanks guys ill go out and get a set of 16mm hubcentrics made then...just bought some lattice style porsche 924 alloys .... :)
sonofsam
Thanks guys ill go out and get a set of 16mm hubcentrics made then...just bought some lattice style porsche 924 alloys .... :rolleyes:
porsche alloys fit a 205 then?!
I'm pretty sure they are 5 stud.
Arahan
Could be the hubcentric spacers he's getting made are adaptors too, from pug to porsche.
I take it back, according to this link /some/ 924s are 4x108 ET15 which should go straight on! :rolleyes:
Jrod
Depends on centre bore aswell?
That link says 57.0 for porsche and pug is 65 so they won't fit without spacres that change the bore.
Edited by Jrod
yep, though the centre bore is a different size, same as older Audi's and SAAB's.
Guest NickMiami
Porsche 924 alloys....they will fit.......
:rolleyes:
Edited by NickMiami
Guest NickMiami
These are the wheels, they will need refurbing before going on and i think ill probably have the centre bore machined out
I thought i'd try and do something original....
:rolleyes:
tom_m
if you're going to the trouble of getting spacers made just have the wheel spigot made the correct diameter for the wheels, saves you extra machining cost!
Guest NickMiami
As i've found out they are ET15 so will fit straight on...as i said ill just have the centre machined out so they fit on the hub...
tom_m
:rolleyes:
mint
