Bassman
Top-end Chatter
Bassman
My 405 (XU7) has been making a chattering noise under load for a while now and it has started to irritate me. I thought it was probably a consequence of wear (148k miles now), but I also changed the cambelt as this had 70k on it, this made no difference.
I had to fill up today and the Shell garage I normally use had run out of 95 RON unleaded so I filled up with V-Power. This has seemed to make a difference and the chattering has stopped on all but the steepest hill near where I live, which if I floor it in 2nd the chattering returns and is obvious again, although probably not as bad as before.
Bearing in mind that this car has a full motronic ECU with wasted spark ignition, so no dizzy to advance / retard. Is there anything I can do to try and prevent / minimise this happening with 95 RON? Would adjusting the cam belt (I believe the XU7 engine has some adjustment in the pulley) help?
Rob
GTI6BOY
i had the same problem with 17" wheels, gone back to 15s now and its gone
ALEX
Sounds like fueling is out, are the injectors clean?
Not a good solution but might be worth trying some redex or something similar.
Edited by ALEX
Bassman
Good idea, I pass Halfrauds on the way home, so I can grab some redex and smoke the neighbours out tonight. :)
Not sure about the state of the injectors, they haven't been touched in 12 years, so they could be under-performing.
