Stu 18 Posted October 28, 2007 As above peeps, ive searched through pretty much all of the past posts on the Mi16 conversions, wiring conversions and such and have found a wealth of info on the transplant side of things, which has verified that ive got the connections correct on the multi-plugs. But, ive got some other issues that i need a wiring diagram to sort. my haynes only has the MP1.3, ive searched high and low but as yet have come up with nowt. The problem is that the car doesnt start, ive got a pin-out diagram for the ecu, and it seems i havent got the reference voltages where i should have them, ive got a spark, and can get the fuel pump to work by supplying the 'pump driver' pin on the ecu with 12v. But it still doesnt fire, are there any test guides anyhwere to check things like the amp, coil pack, CAS, etc resistances? I really need a wiring diagram! Also, what should the injection relay and fuel pump relay look like? are they the same? Mine are both green, 4 tag, 2 for the coil and 2 for the N/O contact. Is this correct? Does anyone have/can point me in the direction of a wiring diagram please? Share this post Link to post Share on other sites
Hilgie 16 2 Cars Posted October 28, 2007 http://www.205gti.com/downloads/wiring.xls Share this post Link to post Share on other sites
Stu 18 Posted October 28, 2007 http://www.205gti.com/downloads/wiring.xls Thanks bud, ive got a similar diagram from a post on here, its the actual wirng diagram from the car showing the ECU and its connections i need, similar to the Haynes 'engine management' diagrams. Share this post Link to post Share on other sites
yorkshirekowboy 19 1 Cars Posted October 28, 2007 http://www.205gti.com/downloads/wiring.xls hilgie where does the 3, M47B coolant fluid level wire connect on the 405 loom? im stuck on this, as that wire on my 205 plug is a thick yellow and green like a earth,....plus the ground (M) on the 405 plug, where does that connect to if theres not ground wire on the pug 205 loom/plug? i was thinking because the M47B has the "M" maybe if connects to the ground on the 405 plug???? cheers danny Share this post Link to post Share on other sites
Hilgie 16 2 Cars Posted November 20, 2007 i was thinking because the M47B has the "M" maybe if connects to the ground on the 405 plug????cheers danny That is correct! Share this post Link to post Share on other sites
