Spiky 37 Posted October 28, 2007 (edited) want to fit some braided stuff Edited October 28, 2007 by Spiky Share this post Link to post Share on other sites
welshpug 1,657 Posted October 28, 2007 I'm guessing you mean the rubber bit not the metal bit? there's 2 different sizes used on the gti6 fuel rail, I'll check for you shortly.. right the original engine uses 7x13mm rubber pipe as far as I can figure out from the diagrams, what filter are you using? as for the gti6 rail It doesnt state what the pipes are as it all comes as one unit (the 2 plastic pipes clipped together) i'll be out under the bonnet of mine later so I'll measure it then (I've got some braided hose to fit too ) Share this post Link to post Share on other sites
Spiky 37 Posted October 28, 2007 so it's 7mm ID on the OE 205 gti cheers dude i'm going to have the std pump feed my swirl pot, then i'm fitting a cossie filter then a 2wd cossie pump then a filter again then onto the engine Share this post Link to post Share on other sites
