Spiky
What Size Is The Fuel Pipe?
Spiky
want to fit some braided stuff :ph34r:
Edited by Spiky
I'm guessing you mean the rubber bit not the metal bit?
there's 2 different sizes used on the gti6 fuel rail, I'll check for you shortly..
right the original engine uses 7x13mm rubber pipe as far as I can figure out from the diagrams, what filter are you using?
as for the gti6 rail It doesnt state what the pipes are as it all comes as one unit (the 2 plastic pipes clipped together) i'll be out under the bonnet of mine later so I'll measure it then (I've got some braided hose to fit too :ph34r: )
Spiky
so it's 7mm ID on the OE 205 gti
cheers dude
i'm going to have the std pump feed my swirl pot, then
i'm fitting a cossie filter
then a 2wd cossie pump
then a filter again
then onto the engine
