josh1990 0 Posted October 27, 2007 I started to lower the back of my rallye today, dropped the passenger side doddle lowerd it 35mm, i then attempted to lower the drivers side, but couldnt get the torsion bar out! what an a*se! I was using threaded rod to draw the bar out but the nut kept buggerin up so what can i do next, i dont fancy taking the beam all the way off (bleeding brakes) Any other ways you guys have found works let me know. Cheers Josh Ma search dint help Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted October 27, 2007 Did you lower it by the spline method or with both ends of the torsion bar free from the radius arm & tube? YoU don't need to remove the arm very far to turn it by one spline so there should be enough slack in the brake line to pull the arm out of the tube enough to turn it one spline down without disconnecting anything. Other than that you'll need a slide hammer to get it free or strip the whole beam. Graham. Share this post Link to post Share on other sites
welshpug 1,666 Posted October 27, 2007 it is possible to remove the beam without disturbing the hydraulic circuits, but it still involves removing the drums. Share this post Link to post Share on other sites
Dj_mini 7 Posted October 27, 2007 You could try putting two nuts on your pulling rod this some times helps give that bit extra. Or wind in the end float on the stud on the other end of the tb then wind in a bolt to the other end with a few nutts on so its solid nuts from bolt head to tb then beat this in with a hammer this will get the bar moving all be it in the wrong direction then once its moved a bit go back to your orignal method to remove the bar completley. Hope this helps. Share this post Link to post Share on other sites
josh1990 0 Posted October 27, 2007 Thanks for the help people, have another go tommorow, reasses my ways of doin it. Cheers Any mor help apreciated. Josh Share this post Link to post Share on other sites
josh1990 0 Posted October 28, 2007 Got it Done today with a bit of help from nearly everyone down the street, and Pug torque lol, lowerd the car 40mm will get some pictures up later, Thanks Josh Share this post Link to post Share on other sites
dodsworth_gti 11 Posted October 29, 2007 glad to here its sorted mate knew the arb would have to come off gimmie a pm about that arb if you want? Share this post Link to post Share on other sites
josh1990 0 Posted October 30, 2007 glad to here its sorted mate knew the arb would have to come off gimmie a pm about that arb if you want? Yeah Massive relief, thought id have to raise other side lol, sure did, yeah i'll tek the ARB mate, Cheers Josh Share this post Link to post Share on other sites
DaveW 6 Posted October 30, 2007 Good to hear its done now. did you fit any upgrades? Share this post Link to post Share on other sites
josh1990 0 Posted November 2, 2007 Yeah newish Gti shocks got put on today, my others were hammerd lol, all seized. Just need that bigger ARB then the back end is done Cheers Josh Share this post Link to post Share on other sites
engelbert 0 Posted November 6, 2007 Hello just a question for ya, is yer rallye standard other than gti shocks and lowering? ie no gti rear beam or arb? if yes how does it handle?? i want to do shocks and lowering on mine but tight budget so doing it myself so don't want to get into the rear beam etc yet, so would be nice to here yer opinion of it cheers Leon. Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted November 7, 2007 If your beam is the same spec as Josh's, replace the spindle thin (14mm) rear anti roll bar with a GTi one (19mm) that'll make a major difference to how it feels on the road imo. Graham. Share this post Link to post Share on other sites
engelbert 0 Posted November 11, 2007 Cheers for that Share this post Link to post Share on other sites
josh1990 0 Posted November 12, 2007 Yea its not too bad really, can do it for nowt but i replaced rear shocks, supposed to be £20 but chrisG give me em for nowt, It wasnt so bad, As long as you sort of no what to do, which i did'nt lol Keep us updated on how you get on! Josh Share this post Link to post Share on other sites
Rupes 0 Posted January 5, 2008 How do you replace the rear ARB, I want to upgrade my Rallye too but the Haynes manual doesn't even say there is one? Cheers... Share this post Link to post Share on other sites
Rupes 0 Posted January 5, 2008 Woah, just found the rear beam refurb guide. Maybe I'll leave it until I've got a spare year. Share this post Link to post Share on other sites
kanyeost 0 Posted January 5, 2008 (edited) I think you can do the ARB pretty easily with the beam still on the car provided: 1. You have the right sized bolts: one to remove the ARB end plate so you can withdraw the ARB from the car and a second thinner bolt & big washers to help pull the new ARB back into the end plate when refitting. (i'm sure someone will know the exact bolt sizes if they aren't in the guide). 2. The thread in the end of the new ARB is ok, if not get it re-cut before starting so that you can easily insert the second bolt when refitting (see pic 41 of the beam refurb guide). You might also have to dig the plastic end cap out before you get started if it's stuck. I find hammering torx sockets in ever increasing sizes into it and undoing does the job eventually, just be careful of the thread. It's all pretty straightforward really, I've done it a couple of times and know nothing. Well worth it too when combined with GTI rear dampers and struts up front. Attack one down your local scrappy for a test run first if you can be bothered but I'd just get stuck in. Edited January 5, 2008 by kanyeost Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted January 6, 2008 Swapping the rear arb can be done in about an hour, all you need is a spare Bendix front caliper mounting bolt (M12 x 1.5) (easy to find on 205's at a scrapyard), a couple of M8 bolts & a decent socket set. Graham. Share this post Link to post Share on other sites
