Ethos 0 Posted October 25, 2007 Hi guys, Yes another topic sorry! There seems to be an air leak from one... just wondering where I could get some? What size are they etc... (205 gti 1.6 1992) Hopefully this will help the idle and maybe even give some bhp back! Thanks Share this post Link to post Share on other sites
j_turnell 137 3 Cars Posted October 25, 2007 You sure the air leak is coming from there, i take it it leaks fuel aswell?? Im sure you will be able to get them from pug for a few pence. Share this post Link to post Share on other sites
Ethos 0 Posted October 25, 2007 You sure the air leak is coming from there, i take it it leaks fuel aswell?? Im sure you will be able to get them from pug for a few pence. Yea, pretty sure. When I sprayed some carb cleaner around the whole the revs dropped loads Ordered some today, £11 all in for 4. Bit more than expected but still all good. Share this post Link to post Share on other sites
KRISKARRERA 2 1 Cars Posted October 25, 2007 £11 for four bits of rubber!? Ineed to do mine, surely there's somewhere cheaper than the main stealer? Share this post Link to post Share on other sites
pacey205 2 Posted October 26, 2007 I went to my local bosch dealer and got them from there, a hell of a lot cheaper than pug if I remember correctly. Im afraid I cant remember part numbers buit if youve got the injector numbers they should be able to find suitable washers for you. Michael Share this post Link to post Share on other sites
Ethos 0 Posted October 26, 2007 I went to my local bosch dealer and got them from there, a hell of a lot cheaper than pug if I remember correctly. Im afraid I cant remember part numbers buit if youve got the injector numbers they should be able to find suitable washers for you. Michael I probably could get them cheaper but at least this way I know i'll be getting the right ones. Got a sump plug from my local parts dealer and he gave me the wrong one £11 is expensive for what it is but it's probably only £5-6 more than somewhere else and I def know they will be the right ones. Share this post Link to post Share on other sites
Rob_the_Sparky 9 Posted October 26, 2007 If you get injectors cleaned (£12 each) then you get all the seals and rubbers replaced as part of the price... Share this post Link to post Share on other sites
Ethos 0 Posted October 26, 2007 If you get injectors cleaned (£12 each) then you get all the seals and rubbers replaced as part of the price... Thanks mate, £48 is alot more than £11-12 though and trying to keep the price down on everything as much as possible Out of interest are the "injector" cleaners you can get anygood, the ones you put in with your petrol? Share this post Link to post Share on other sites
Rob_the_Sparky 9 Posted October 26, 2007 I've only tried the in the fuel stuff once on a petrol and once on a diesel. Both times they were a waste of time. Cleaned injecotrs gave a bit more power top end on both the 1.9s I've had it done on but it isn't a dramatic change. Share this post Link to post Share on other sites
