Edp 67 3 Cars Posted October 24, 2007 Can someone recommend decent CV boot kits. I now need two outer ones on my Mi. The car seems to eat these pesky rubber crappers and i want to know if there are any more robust than others? I always install as the instructions say and i always use the metal straps unlike others who use cable ties. The drivers one hasn't been on there more than 3 months, grease bloody everywhere The ones I normally get are the flexible ones installed using the cone from my local motor factors. The car is lowered 25mm and has 309 bones/shafts. Any suggestions appreciated. . . Share this post Link to post Share on other sites
chris1986 1 Posted October 24, 2007 is it the actuall boot splitting or the clip comming off. we use a universal boot, meca tech and have no problems with them. they come with clips and grease Share this post Link to post Share on other sites
welshpug 1,675 Posted October 24, 2007 I always split the joint and use whatever GSF supply, which is usually Meillor which IIRC are O.E (or at least o.e quality) there's nothing wrong with using cable ties to secure them either, you just need to make sure that they're made from a decent material so they can take some tension, its often quite difficult to secure the metal clips without the correct tools. Share this post Link to post Share on other sites
Edp 67 3 Cars Posted October 24, 2007 Yeah its not the metal clips coming off its the rubber splitting. Maybe i'll try the more hard wearing kit and like you say split the joint instead of using the flexible type. Share this post Link to post Share on other sites
