ifcho 0 Posted October 22, 2007 Hi, I'm preparing a hillclimb 205 and at the end of the month it is going to a workshop to have a rollcage fitted. The cage is custom build and now I'm wondering is it worth fitting a rollbar under the windscreen, I mean here: (the pic is from another topic I found here) Obviously I won't be able to use the dash anymore, probably I will also have problems fitting the air ducts but I'm thinking of fitting two electrical heaters instead of the standard heater matrix and blower. Do you think that such bar will improve the overall strength of the rolcage, I think that in a side impact this additional rollbar will help significantly. . Share this post Link to post Share on other sites
bren_1.3 1 Posted October 22, 2007 i dont think ive ever seen any 205 roll cage with a bar across the front bulkhead. i wouldnt bother personally. Share this post Link to post Share on other sites
Dj_mini 7 Posted October 22, 2007 Iv got a custom weld in cage and have run a bar across there and picked up the steering colum aswell. Iv seen quite a few of the weld in cages do this. Cheers Dan Share this post Link to post Share on other sites
philfingers 5 Posted October 23, 2007 The custom cages one comes with a bar across under the screen. You can't fit the heater box but can fit the dash. Ok if your going to fit a heated screen in a hill climb car. Share this post Link to post Share on other sites
