Pob
Valve Clearance
Pob
Hi,
I have a 1.9 with a Piper 270 cam, any ideas what should the valve clearance be?
Dan
Sandy
0.2mm inlet and 0.25mm exhaust, according to their catalogue.
Pob
Thanks for the reply a great help
Thanks again,
Dan
Pob
Hi all,
I posted this question a while back, I've just used my car for the first time since picking it up and wondering how 'ticky' should it be? Because of the increased valve clearance I know it will be louder than normal, mine is quite loud I'm just wondering if the clearances need doing.
Thanks,
Dan
If you set them to the clearances above it shouldn't be bad imo.
Have you got a cracked exhaust manifold?
Gaham.
Pob
Gaham.
Possibly, I can smell fumes around the back of the engine, but Its differently coming from around the cam cover. It is quite loud, Its the most prominent sound when driving. I haven't done the valve clearances yet, do you think they will be out?
Thanks,
Dan
If you've put a different cam in then it's entirely feasable that the valve clearances will be way out, particular if the BP270 cam that you've got is a regrind rather than one ground from a blank. Only takes a few minutes to remove the rocker cover and check the valve clearances - all you need is a set of feeler gauges.
Pob
Gaham.
I checked the clearance's a couple of days ago, Exhaust and Inlet are all 0.2mm. I don't think the tappets are causing too much noise, I listened to it today when I first started it cold It was quiet, by the time I got home there was a noticeable increase in ticking. When turning the heater on when cold, it smells of exhaust fumes, would I be right in thinking either the manifold has cracked or the gasket has gone?
Any tips on removing the manifold? I don't want to snap a stud off in the head like the previous owner did on my last one :)
Many Thanks,
Dan
brianthemagical
it's not the injectors is it, per chance?
