Bam 0 Posted October 21, 2007 hi, i'm looking for some good ideas to map the ecu myself. i know what i'm doing, but dont know what would be the best solution. so i'm looking for a solution, where it is possible to acces the correct map from stock ecu, "adjust" the correct map and run with perferct lambda. (maybe it shows the lambdavalue (measured by oxygen-wideband-sensor) on a display?!) fit-adjust-run methode (looking for a solution without any converting from hex and difficult formula's and without any further hardware like epromer,multimeter etc. or rolling road/dyno) any ideas? regards Share this post Link to post Share on other sites
cybernck 402 1 Cars Posted October 22, 2007 for control, you could use VEMS WBO2+EGT solution, like i have. as for re-mapping the standard ECU... Share this post Link to post Share on other sites
