Guest gt6jim Posted October 19, 2007 I ordered a 1.6 GTi Dissy Cap and Rotor arm set from GSF. However they do not fit, the cap is too small and the arm is 180 the wrong way round, and a different shape too. Did 1.9s have a Bosch dissy different to the 1.6, as my current stuff has Bosch stamped on it. I'm thinking it may be a 1.9 dissy? Cheers, Jim Share this post Link to post Share on other sites
steve@cornwall 100 Posted October 20, 2007 I ordered a 1.6 GTi Dissy Cap and Rotor arm set from GSF.However they do not fit, the cap is too small and the arm is 180 the wrong way round, and a different shape too. Did 1.9s have a Bosch dissy different to the 1.6, as my current stuff has Bosch stamped on it. I'm thinking it may be a 1.9 dissy? Cheers, Jim 1.6 and 1.9 use same cap and rotor arm. Ducelier clips on, bosch bolts on. I'd say they supplied the wrong parts.............there's a surprise (not a dig at GSF, I've never used them, just factors in general) Share this post Link to post Share on other sites
Miles 331 1 Cars Posted October 20, 2007 1.6 & 1.9 caps do vary from yr to yr, It's only the later 1.6's that use the screw on cap, The pre CAT ones are all Bosch where the CAT one's are Ducelier (Same as base models) Share this post Link to post Share on other sites
Guest gt6jim Posted October 20, 2007 1.6 & 1.9 caps do vary from yr to yr, It's only the later 1.6's that use the screw on cap, The pre CAT ones are all Bosch where the CAT one's are Ducelier (Same as base models) My current cap bolts on, but the new one has bolt holes, it's just physically too small. Small diameter. The new arm has a fan shaped tail too, where as the current one is just rectangular? Share this post Link to post Share on other sites
petesy71 0 Posted October 20, 2007 My current cap bolts on, but the new one has bolt holes, it's just physically too small. Small diameter. The new arm has a fan shaped tail too, where as the current one is just rectangular? i had the same problem with a replacement cap (magneti marelli) from gsf. the bolt holes on the orange bosch cap are a bit wider. the magnetti one fitted onto the dizzy on my base model. Share this post Link to post Share on other sites
welshpug 1,666 Posted October 20, 2007 sounds like a TU cap. Share this post Link to post Share on other sites
