ChrisG
Rear Arm Removal
ChrisG
***before I start, the search function has been disabled so I could not carry one out, though I did try :) ***
Want to lower the back end of my pug (309GTi rear beam) but the torsion bars are stuck fast :)
I've heard another way of doing it is to remove the rear arms, but not really sure what to do.
Can someone do me a very quick guide to get me started please :angry:
josh1990
If you need some help chris theres a mechanic at 38, :) i need mine lowerin too. :angry:
steve@cornwall
Hi guys. There's a very useful article on this on the main site, everything you need to know
Stu
In my experience you need a BIG slide hammer to get stuck torsion bars out, i ended up making one with 12.5 kilo weight and 1m slide.
It does have a nasty tendancy to try and pull the car off the axle stands at the same time however.. :angry:
The guide on the main site tells you all you need to know, just make sure you get your neighbours permission before hooking your beam over their wall and hammering the s*it out of the radius arm! lol!
PM me if you get stuck bud, theres also a few peeps on here who are very familiar with the beams, Welshpug, Alastair to name but two.
Ahl
It can be a royal pain in the arse. I used a sledge hammer!
taylorspug
For a basic lowering job you wont need to copletely remove the torsion bars, you can take the arms out with the bars still in them and just refit them 1 spline lower. If its a pain to even get the arm out of the beam tube then the beam is probably seized and therefore scrap anyway. :)
ChrisG
Cheers lads, going to be giving it a go over the next week (between shifts at work) so I'll let you know how I get on :mellow:
ChrisG
Quick update....both arms came off fine and everything looks peachy!
One torsion bar was stuck solid but took it to work and had it pressed out, cleaned everything and greased all bearings.
Other side was fine, no probs at all getting torsion bar out, but still stripped, cleaned and greased it all.
Only prob now is I lowered it too much, but I'll sort that tomorrow ;)
Ahl
Wow! A non-knackered rear beam - thats a rare find! :wub:
Chris, I can bring my dummy shock over on Sunday if you want so you can set both sides the same accurately to any height you want. :wub:
Graham.
