Silky 33 1 Cars Posted October 17, 2007 Looking to change the driveshafts on my 1.6 GTI. Apart from the shafts themselves, which other parts will I need to replace while doing it, seals/bearings etc ? Could someone list what I'd need, part no's would be handy if anyone has them Sorry for not doing a search but the function is not available at the moment Thanks Michael Share this post Link to post Share on other sites
welshpug 1,676 Posted October 17, 2007 Peugeot say you should replace the balljoint bolts, its also a good idea to replace the driveshaft seals in the diff housing. apart from those items thats it (assuming the new shafts come with new Hub nuts) part numbers to follow... Share this post Link to post Share on other sites
Silky 33 1 Cars Posted October 17, 2007 Do new shafts come with new hub nuts ?! Share this post Link to post Share on other sites
welshpug 1,676 Posted October 17, 2007 (edited) they usually do, but it depends if they're staked or R clipped ones, 205's are usually staked IIRC, so a new nut should be used (and supplied IMO) left seal is 3121 44, and right seal is 3121 46. Edited October 17, 2007 by welshpug Share this post Link to post Share on other sites
tagy 1 Posted October 17, 2007 Don't forget the gear oil I prefer to get new balljoint nuts & bolts from Peugeot as well, just incase. Share this post Link to post Share on other sites
welshpug 1,676 Posted October 17, 2007 Don't forget the gear oil I prefer to get new balljoint nuts & bolts from Peugeot as well, just incase. DOH! of course, 75W80 is the grade required accept no substitute! Share this post Link to post Share on other sites
Silky 33 1 Cars Posted October 18, 2007 So to re-cap..... 75W80 Gearbox Oil Balljoint Nuts & Bolts Driveshaft Seals Hub Nuts Share this post Link to post Share on other sites
welshpug 1,676 Posted October 18, 2007 yep, as well as tools Share this post Link to post Share on other sites
Pugnut 9 1 Cars Posted October 19, 2007 remember to slacken the driveshaft nut before you dismantle anything. If you have the standard 1.6 wheels you will need to borrow a wheel with a centre cap so you can have the wheels on the ground while you get the nut undone .(1.6 alloys have no centre cap) i use a deep socket (35mm for the 1.9 and iirc its 32mm for the 1.6) and my 1/2 extendable breaker bar is usually just enough to slacken them(i've had to use scaffold bar before ) Share this post Link to post Share on other sites
Stu 18 Posted October 19, 2007 As above the driveshaft nuts can be really tight, ive had to use a 3/4 socket in the past and a big jack handle.. Other than that i think you've got everything, i bought a set of driveshaft oil seals from pug recently, and they arent cheap! Well worth doing though. Share this post Link to post Share on other sites
