mr2haz
Gti 1.9 Head Gasket
mr2haz
Please could someone confirm the best way and how difficult the task of changing the head gasket is? Is it a job that requires removing the engine? I there any parts I should change while doing this job apart from the cam belt.
boldy205
It can be done with the enging in place, get a Haynes book of lies, it will help a lot.
Things to change are belt, tensioner, and waterpump if you want to do a propper job!!
j_turnell
Also to do the stem seals, lap the valves, check valve guides.
mr2haz
So just the normal stuff then?
AdamVester
yeah its a very easy job... shouldnt take more than 4hs if your confident.... we spend about 1h doing one (the worst bits the manifold) getting the bolts undone is a job on its own lol... we ended up smashing them off as we were only fixing the head gasket on the engine to see if the engine was a goodun or not to put into another car.. but yeah easy job worst parts the manifold...
joelpsmith
Christ! is that with the engine and everything else still in the car.
