Kennyb
Cams..... How To Tell If I've Got Em?
Kennyb
Ok trying to work out exactly all the work that the prvious owner had done to the engine so i can build on it.....he told me it had kent cams but had no idea about which they were etc and no reciept.......hows best way to find out if it has? It revs way past 6250 or whatever the limit is??!? :lol:
Grahamrally
All aftermarket cams should be stamped on one of the ends with a part number directly or indirectly relating to that cam and the company that made it, unless it was something someone machined up in their shed! That's the easiest way to tell really.
Graham
Kennyb
Graham
Cool, how do i find out what part numbers relate to which cams???? is there only really kent ones that are off the shelf?? Cheers
M_R_205
Have a look through thair website it should tell you all the info about them, or post it up on here and someone will no doubt tell you what it is
Blank cams will have a part number stamped on them, normally on the end, Reground cams dont have this thou so you can only tell by the machining marks
j_turnell
Just take the rocker cover off and have a look, failing that they are usually stamped on the dizzy end so can remove that and take a look, just remember to mark it for the timing.
