damien 22 1 Cars Posted October 15, 2007 hi ya jumped in her this morning and she wouldnt start. she wont turn over or anything she is just dead, all you can hear is the fuel pump buzzing. she was fine last night when i finished work where do i start to look for the problem? thanks Share this post Link to post Share on other sites
damien 22 1 Cars Posted October 15, 2007 removed the starter and found out that the spade connector had broken off so ive got to solder it back on. no worrys Share this post Link to post Share on other sites
dicko73 0 Posted October 30, 2007 i've had a similar problem, with the same symptoms for ages, and no amount of kicking in asda car park would make it work. only seemed to do it when engine was hot though, but thanks to this forum i've wired the starter solenoid straight up to the orange starter wire on the barrel and hey presto!, the problem seems to have gone. relief. Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted November 1, 2007 Unlucky but an easy fix. Just get a newer starter with the stud & nut for the solenoid wire & crfimp a ring terminal in the spade connectors palce, much easier & avoids a reoccurance. Graham. Share this post Link to post Share on other sites
Batfink 201 Posted November 1, 2007 I think half our cars would be completely different if we rewired all of them! Share this post Link to post Share on other sites
damien 22 1 Cars Posted November 1, 2007 Unlucky but an easy fix. Just get a newer starter with the stud & nut for the solenoid wire & crfimp a ring terminal in the spade connectors palce, much easier & avoids a reoccurance. Graham. problem with mine was that the spade was still on the connector but the lead had broken off, i just solderd the lead straght onto the terminal which will stop it happening again but not too great if i need to replace the starter Share this post Link to post Share on other sites
