MartinM
Rear Beam Question #637
MartinM
Can I just pull it in using a piece of 12mm studding, some nuts and plates - or will it need a hydraulic press?
MartinM
OK...lets get the terminology right :blush:
Can I pull a brand new trailing arm shaft into a trailing arm using a piece of 12mm studding, some nuts and plates - or will it need a hydraulic press?
I'd just try it, but the only piece of decent studding I've got (12mm) is two inches too short :blush:
You'd be far better to find use of a press, they normally take 2 tonnes minimum to press out & back in again so its more than likely strip the M12 thread before it moves anywhere imo.
Graham.
MartinM
Thanks - I suspected as much.
...goes off to find a hydraulic press....
