dean
Gti6, Which Clutch?
dean
does any one no wat clutch to use when putting a gti6 and gearbox into a 205 cheers dean
nearly right! 1.9 Mi16 clutch, 2.0 mi16 pressure plate is identical to the gti6 clutch, but still 215mm diameter and the same spline patterns.
dean
and will that fit with a gti6 box
nope, for the GTi6 box you need a 2.0 Mi16/S16/GTi6/XSi etc clutch to use the gti6 box
(nearly all the XU10 and XUD9T clutches are the same "Pull type")
dean
ok so then what clutch cabel will i need to use so it will fit the box and the bulk head on the car
for which box? and is the car BE1 or 3?
dean
for the gti 6 box. the car is an opposite 5th reverse, so obviously i would need to get a lift up reverse cable.
Hilgie
You can retain your current BE3 cable, but you will need to add a lift up reverse from a BE1 car.
dean
what so use a be3 cabel and a standard gti6 clutch
