DamirGTI
Exhaust Mainfold
DamirGTI
Hello !
Please can somebody help me out , I need advice regarding exhaust mainfold repair .
It's OE Peugeot exhaust mainfold and it blows out at the corners , I've try all sorts of mainfold gaskets , sealants etc. but all of them was just temporary fix for 5-6 months and it started to blow out again ..
Well the problem is because contact surface of the mainfold isn't flat on the two end corners , it haves 2-3mm deep craters from where it blows gases out (you can see that on pictures as black areas on the corners ..) , and I can't seal this surface to make long term gas tight seal with any brand of exhaust mainfold gaskets or high temp. gasket sealants ..
So I'm looking for some tips on how to repair this manfold surface on the corners ?
Can I mill/grind entire mainfold 2-3mm down in order to make fresh flat contact surface ?
Or can I just weld this craters on the two end mainfold corners and then grind this welded area back down to the original contact surface ?
Something else maybe ?
Thanks !!
Damir
pics :
http://s27.photobucket.com/albums/c151/Pie...stmainfold1.jpg
http://s27.photobucket.com/albums/c151/Pie...stmainfold3.jpg
http://s27.photobucket.com/albums/c151/Pie...stmainfold4.jpg
http://s27.photobucket.com/albums/c151/Pie...stmainfold2.jpg
jeremy
Possibly weld then skim, if not then just skim and new gaskets.
Tried Loctite 5920??
It can be welded but as it's cast it's a specialist job, may be difficult to get hold of for you but you may be better off getting a replacement.
DamirGTI
Hi !
I've been welding this cast exhaust mainfolds before (well not this one but the spare one which had one crack inbetween 1-st and 2-nd cylinder ..) first i was preheating the mainfold in the oven up to 200-250C :D and then preform welding (with special welding rod for cast iron ..) on hot mainfold :) and it was good no problems what so ever after the welding , like brand new item ! ..
But this mainfold is the best of all i have apart from that contact surface imperfection :)
So what's this Loctite 5920 ? some sort of high temp. liquid metal ?! does this stuff works :mellow:
@jeremy
Yes i was thinking just to get it skim down a bit , but i don't know how much is allowed for cast mainfold skim :ph34r: what i mean can it beak after when it gets hot or something ?! (if it's skimmed too much...)
Cheers !
Damir
jeremy
I have used a skimmed one before, I will try an measure the thickness for you tomorrow if I can find it.
steve@cornwall
Not sure on the skimming etc, but I'd replace the mounting studs in the head as I've had manifolds warped like tis before, and only noticed when the studs have broken. Some have been warped enough not to fit on good studs (when fitting s/h manifolds) and have needed the holes enlarging to fit comfortably
DamirGTI
Hi !
All exhaust mainfold studs are replaced this year when i was rebuilding this engine :)
DamirGTI
If you can - please ! it will be nice to know :)
Did you have any problems with that skimmed mainfold ?! :) ( bending , distorting , cracking , blowing out etc. ?! )
Thanks ! B)
Damir
jeremy
Ok sorry for the slow response. Just measured the thickness from the mating edge of the manifold to head to the face where the manifold stud nuts srews upto. The reading is an average of 10.5 to 11mm thick. When on the car I never had any problems with leaks. Hope this helps you.
DamirGTI
Hello !
Yes :wub: excellent , thanks a lot Jeremy ! :lol:
Regards :)
Damir
