Stu
Help! Mi Liners Orientation!
Stu
As above peeps, i pulled the liners out of the mi block complete with the pistons ready to rebuild but didnt make their orientation, i did number them though. i havent rotated the pistons in the pots so i can only be 180 degrees out (i hope) is there a way to work out the piston/liner orientation? the pistons have little arrows with 'dist' next to them, should these all be pointing the same way? if so, which way?
Ryan
'dist' is short for something french that means timing belt, so they should all point towards that end.
boldy205
Dist means Front, and as said should point to the belt end.
Stu
Many thanks people! ;)
