Stu 18 Posted September 24, 2007 As above peeps, i pulled the liners out of the mi block complete with the pistons ready to rebuild but didnt make their orientation, i did number them though. i havent rotated the pistons in the pots so i can only be 180 degrees out (i hope) is there a way to work out the piston/liner orientation? the pistons have little arrows with 'dist' next to them, should these all be pointing the same way? if so, which way? Share this post Link to post Share on other sites
Ryan 99 Posted September 24, 2007 'dist' is short for something french that means timing belt, so they should all point towards that end. Share this post Link to post Share on other sites
boldy205 75 Posted September 24, 2007 Dist means Front, and as said should point to the belt end. Share this post Link to post Share on other sites
Stu 18 Posted September 24, 2007 Many thanks people! Share this post Link to post Share on other sites
