fore_heed 0 Posted September 23, 2007 My 205 has recently started to develop a 'ticking' noise when warm. I'm not sure whether its the tappets or something else, im no mechanic! I've changed the oil recently, but made no difference. I'm not sure if its something i should be majorly worried about or not? Engine still revs well through all the gears, doesnt seem to be any lack of power. Any help would be much appreciated! Cheers Share this post Link to post Share on other sites
danpug 1 Posted September 23, 2007 Sounds like tappets most likely but possibly a crack in your exhaust manifold. Share this post Link to post Share on other sites
alexmi16 0 Posted September 28, 2007 seconded - crack in exhaust manifoldor manifold gasket Share this post Link to post Share on other sites
jim21070 2 Posted September 28, 2007 (edited) Injectors can tick very loudly on idle sometimes. I'll third the exhaust manifold though. Easy way to check. Get your nose right in the engine compartment as near to the manifold as possible and take a deep sniff. If you can smell exhaust fumes it's the manifold. If you don't know the smell, give your tailpipe a sniff first, wait about 10 mins and then go back to sniffing in the engne bay Edited September 28, 2007 by jim21070 Share this post Link to post Share on other sites
Mad Professor 7 Posted September 28, 2007 My engine still taps after adjusting valves, buckets, tapits, ect. So I have just ordered my self a set of Automotive Stethoscope's. Somthing like. I hope this will help to pinpoint the noise. Share this post Link to post Share on other sites
jim21070 2 Posted September 28, 2007 My engine still taps after adjusting valves, buckets, tapits, ect. So I have just ordered my self a set of Automotive Stethoscope's. Somthing like. I hope this will help to pinpoint the noise. You just need a white coat now to go with it I always find a long screwdriver with a nice smooth plastic handle does the job pretty well. You need to choose one that is a nice snug fit against your ear and with no rubber in the handle to dampen the sounds. I use an old-style smooth yellow handled No. 4 "Footprint" as was used by BT telephone engineers years ago. If it is still tapping after all of thet work then the cam might be the cause... Share this post Link to post Share on other sites
fore_heed 0 Posted September 29, 2007 Cheers guys! Now that you mention it, I do smell some exhaust fumes when im at a standstill after a run. I'll be sure to check it out! Share this post Link to post Share on other sites
CaptainK 11 Posted October 1, 2007 Mines started ticking as well, so I'll give that a look as well. Thanks. Share this post Link to post Share on other sites
Rob_the_Sparky 10 Posted October 2, 2007 A cracked exhaust manifold is louder under load than off load (due to higher exhaust pressure at a guess) but tappets/injectors are teh same across engine loads. Generally the easiest way to tell whether it is the manifold or not. Rob Share this post Link to post Share on other sites
wardy18 33 1 Cars Posted October 3, 2007 A cracked exhaust manifold is louder under load than off load (due to higher exhaust pressure at a guess) but tappets/injectors are teh same across engine loads. Generally the easiest way to tell whether it is the manifold or not. Rob i did the sniff test on mine and couldnt smell any exhaust fumes, my ticking is definitely tappets as its all coming from below the rocker cover, will need to get some shims and give it a blast one day gotta learn somehow lol Share this post Link to post Share on other sites
CaptainK 11 Posted October 5, 2007 Whats the downside of having a cracked manifold? Would it lead to dodgy emissions / running rich / bad performance ? My 205 ticks quietly whilst maintaining speed at X revs. Boot the acclerator and suddenly the ticks are like a marching band. Release accelerator and there are no ticks at all despite being back at X revs (obviously engine spinning down though as no throttle applied) Share this post Link to post Share on other sites
danpug 1 Posted October 5, 2007 It'll fail an mot and i would imagine that if the crack is serious enough it probably would have an affect on performance. Share this post Link to post Share on other sites
steve@cornwall 100 Posted October 5, 2007 I find that the manifold gaskets are prone to failure,too also giving a ticking noise, esp. under acceleration. And / or the manifold to downpipe gasket. A couple of hours work to replace (if it all undoes and nuts aren't seized and no studs snap!!!!) and about 20 quid parts from pug. Talking of manifold studs....... check that one hasn't snapped off - again all too common on the gti Share this post Link to post Share on other sites
fore_heed 0 Posted October 6, 2007 Anyone know where I can find a decent seller of exhaust manifolds? Had a look round some sites an could only find full systems. Had a look on ebay but its exhaust manifolds are pretty far and few between. Im not looking to spend mega money on one, just somethin decent that wont break for a while will do me! Cheers. Share this post Link to post Share on other sites
CaptainK 11 Posted October 9, 2007 It'll fail an mot and i would imagine that if the crack is serious enough it probably would have an affect on performance. Funnily, mine did fail its MOT on emissions and they "tweaked" it to make it pass. Dunno what. And yes, the performance of my Pug isn't exactly great. Mmm.... I shall look into it. As mentioned above - I'd like to know where to get new manifolds and so forth from. Share this post Link to post Share on other sites
Grim.Badger 15 Posted October 9, 2007 Whats the downside of having a cracked manifold? Would it lead to dodgy emissions / running rich / bad performance ? My 205 ticks quietly whilst maintaining speed at X revs. Boot the acclerator and suddenly the ticks are like a marching band. Release accelerator and there are no ticks at all despite being back at X revs (obviously engine spinning down though as no throttle applied) This sounds more like an ignition timing problem (your engine in pinking). To test, boot it in 5th gear at 30mph; if it is really bad then your ignition timing should be suspected. Share this post Link to post Share on other sites
CaptainK 11 Posted October 10, 2007 This sounds more like an ignition timing problem (your engine in pinking). To test, boot it in 5th gear at 30mph; if it is really bad then your ignition timing should be suspected. I drive around at 30mph in 5th a lot of the time (long 30mph roads in Exeter). And yes, it does indeed make lots of ticking noises when you boot it in 5th at 30mph. Actually, it makes lots of ticking noises when you boot it in any gear. Now you mention it - it could be a timing issue as it recently had a cambelt change, new valves, piston rings, shells etc etc. Maybe it wasn't set back up right? I've only recently noticed it as I've started driving around with the radio panel out (and thus off) a little more often. Share this post Link to post Share on other sites
