jodycraw 0 Posted September 19, 2007 I've got some new screen washer jets as mine are jammed up and don't let anything pass through them... How do the other ones come out of the bonnet? I've only had a quick look at them so far. I had a look on the forum but couldn't find anything.... THanks, Share this post Link to post Share on other sites
Baz 421 Posted September 19, 2007 little tabs need to be squeezed inwards and then they'll release through the hole in the bonnet. Your new ones should give you a clue! Share this post Link to post Share on other sites
engine killer 6 Posted September 20, 2007 I've got some new screen washer jets as mine are jammed up and don't let anything pass through them... How do the other ones come out of the bonnet? I've only had a quick look at them so far. I had a look on the forum but couldn't find anything.... THanks, thin needle should cure the problem, at least it did on my car. by the way, the 405 washer jet bars i am using NEVER jam at all. Share this post Link to post Share on other sites
jodycraw 0 Posted September 20, 2007 did them last night, should have looked at them properly before asking! Amazing how much power you get out of the new ones..... Share this post Link to post Share on other sites
alexmi16 0 Posted September 28, 2007 thin needle should cure the problem, at least it did on my car. by the way, the 405 washer jet bars i am using NEVER jam at all. i find the pin normally cures it too. But you're right. 405 washer bars all the way! how did you plumb the washer hose. Did you go through the scuttle? Share this post Link to post Share on other sites
DaveW 6 Posted September 29, 2007 405 washer jets rule, i ran the hose under the scuttle panel using bits of the 405 hose, 1 T piece and the end L piece, then cable tied the bars to the arms. Share this post Link to post Share on other sites
welshpug 1,666 Posted September 29, 2007 I dont need to pilfer them off my 405's old wipers any more, now I work on trucks for a living theres planty of BIG spray bars on the shelf in the stores Share this post Link to post Share on other sites
