5150maxie
10mm Wheel Spacers
5150maxie
10mm wheel spacer for fitting mi16 15" alloys can some one explain to me why people get wheel wobble?
Rippthrough
Because there's no 10mm hubcentric spacers available off the shelf, so you lose the centring ring and the wheel doesn't go on quite square.
Edited by Rippthrough
5150maxie
can you glue them to the wheel square then bolt them up?also the bolts keep the wheel square?
Edited by 5150maxie
Henry Yorke
I run them fine, but the problem may come if you use standard Peugeot flat faced bolts. I use 60 degree taper ones on my wheels (designed for that though) and they are fine
clifton
henry where did you get your tapered bolts from cause i need some for my superleggeras?
Henry Yorke
Anywhere!! They are much more common than flat faced bolts. I would get some from your local Ripspeed / Halfords place as they have buckets full. I used a stud conversion kit with wheel studs and open ended nuts. If you are running OZ wheels, they may be Ford offset with a spacer so you need really long bolts with a 60 degree taper
Alastairh
Halfords don't mate. Been they're tried tonight for mine <_<
Rippthrough
I've got some +10mm ones, but I've only got 8.... <_<
5150maxie
why do you need 60 degree taper bolts? is it just for after market alloys?
Rippthrough
They pull the wheel central as you torque them up, not always perfectly, but usually close enough, you can only use them with alloys with the correct seat though.
