kevp's 205gti
Gti-6 Alternator Belts Question/
kevp's 205gti
hi guys got a gti-6 lump for my 205 gti, with no PAS.
the engine for the conversion comes with the A/C pump and PAS pumps now as im going to remove them is there another engine in which the belt will fit the gti-6 with out these two pumps?
whizzer71
I used brackets from a citroen ZX and then got a 6PK720 belt from my local motor factor,I have pics if you need them,Pm me your email and Ill send them to you.
Good luck
Tris
kevp's 205gti
seems i need a kit i may have one from a member but not sure yet. can you not just buy a shorter belt neil @ des developments said you can use a shorter belt and modify the tensioner.
any help regarding this ?
t16ryan
Yes mate you can do what i have done and ground the powersteering pump bracket down and fit a 708 5 rib belt and use original gti6 alternator and use a 8v adjuster at the bottom but with the belt and a 12mm spacer there wasnt any need to fit the adjuster at the bottom of mine
http://forum.205gtidrivers.com/index.php?showtopic=79090
kevp's 205gti
ok right that picture shows me more than i new but surely the belts either loose or a pain to get over the pullys as its so tight?
t16ryan
I fitted it over the pulleys then with the 12mm spacer was the perfect adjustment, you can modify a 8v tensioner to go where the bottom bolt would go, jusy bore it out to 10mm and make the gap slightly bigger and will be fine :lol: can send more pics if needeD?
kevp's 205gti
yeah if you could including the 12mm spacer please
dean
just use a hb700e belt from halforld and a 1.4 106 cambelt tensior
danpug
Is that all you needed to do dean?
dean
yer there is a 13mm hole on your engine brackt so just get a tensior like i said and bolt it straight on and it works great
danpug
I'll pop down the scrappy and see whats about. B)
dean
there only about £20 from gsf not to expensive
