dodsworth_gti
Starting Problems
dodsworth_gti
on my mi16
it starts,just,and its getting embarasing,1st of starter went,sent her in for a new one as i couldnt be chewwed to do it,got it back and was starting well,then started clicking and turning over slowely,then i found out it had a 8v starter on,changed this for a gti6 starter,and all was good on 1st time,but then its back to before,slow and clunky and clicky,some times it fires up well though which i cant understand,but i dont htink its on the proper wireing tbh,it has a random wire going from the starter direct to what looks like the barrel or where ever it goe's to up the steering coloumn end
any chacks i can do to start eliminating problems?
thanks
ben
Richie-Van-GTi
clean the earth strap contact points on the gearbox and chassis, refit them with serated washers.
Starter wire direct from barrel to solenoid is a simple well known bypass for all the brown multiplugs to minimise any areas or high resistance due to corrosion etc. IIRC I put that wire in for Chris when I had the car as the original wire broke down somewhere.
dodsworth_gti
cheers mate,dont know why i put it in here :)
