Guest stephen406
Wires Not Connected?
Guest stephen406
Hi All
I have just bought a mi16 converted pug 205 and i am trying to
tidy up the wiring.
One prob i have found is there is a sensor pluging into the exhaust the
wiring from the sensor is not conected to the wiring of the car. There is a plug close
by but it looks to be a different connection and does not reach.
The engine is from a BX and as far as i know so is the loom???
Thanks in advance for any help...
Cheers Stephen
ORB
is your car a later year job ??
It sounds like someone has used a downpipe from a different car & made it fit yours.
The BX 16v never came with a Lambda sensor afaik so your loom won't have a plug to fit it.
Graham.
Guest stephen406
Hi
My car and engine is 1992.
So can i just blank off the hole in the down pipe???
Cheers Stephen.
Yes, you can either leave the lambda sensor fittted or get a bolt the rigth thread, block the hole off & forget about it.
Graham.
