DamirGTI 344 Posted September 14, 2007 Hi ! Is this oil acceptable for BE3 box ? : http://i27.photobucket.com/albums/c151/Pie...is/IMG_5690.jpg I've change oil yesterday but unfortunately i didn't have enough money to buy proper 75w-80 oil so i bought this one ... Oil specs. : DESCRIPTION Mobilube GX-A 80W is an automotive gear lubricant formulated from high performance base oils and an advanced additive system. This lubricant is engineered for commercial transmissions, axles, and final drives where protection against wear and scoring is required. It provides excellent performance in Mercedes Benz applications and where API GL-4 service is required. FEATURES & BENEFITS Today's drivetrain applications place higher performance demands on lubricants. Higher speeds, higher torque, and heavier loads require improved formulations to maximise equipment life and optimise operating costs. Longer service intervals place additional demands on the gear lubricant requiring effective basestock and additive systems. Mobilube GX-A 80W is engineered to meet these challenges. The key benefits include: Good thermal stability and resistance to high temperature oxidation - Extended gear and bearing life due to minimal deposits Longer seal life Excellent rust and corrosion protection - Longer component li Good low temperature lubrication - Reduced wear at start-up and ease of start-up li Compatible with typical automotive seals and gaskets - Minimum leakage and reduced contamination TYPICAL PROPERTIES Mobilube GX-A 80W SAE Grade 80W Viscosity, ASTM D 445 cSt @ 40ºC 76 cSt @ 100ºC 10.0 Viscosity Index, ASTM D 2270 104 Pour Point, ºC, ASTM D 97 -33 Flash Point, ºC, ASTM D 92 216 Density @ 15ºC kg/l, ASTM D 4052 0.89 APPLICATIONS Manual transmissions and drive axles requiring API GL-4 level performance Passenger cars, onhighway light and heavy-duty trucks and commercial vehicles Off-highway industries including: construction, quarrying, and agriculture Other industrial, commercial, and automotive applications including hypoid gears operating under moderate to severe operating conditions SPECIFICATIONS & APPROVALS Mobilube GX-A 80W meets or exceeds the following industry and builder specifications: API - GL-4 Daimler Chrysler MB 235.1 ZF TE-ML 02A/08/17A MAN 341N Mobilube GX-A 80W is recommended for use in applications requiring: ZF-TE-ML 08 So what do ya think ? Share this post Link to post Share on other sites
Batfink 201 Posted September 14, 2007 Its thicker when cold so should be ok. Try it Its not going to ruin the box. 1litre isnt enough though Share this post Link to post Share on other sites
DamirGTI 344 Posted September 14, 2007 However I've fill 2L of this SAE80 oil inside Will go later for a spin and see if it's ok. Thanks ! Damir Share this post Link to post Share on other sites
