skinner2k3
How Much Paint.....
skinner2k3
How much primer and paint would I need to do 1 x 205 front wing from brand new I presume bare metal?
Is there any way round the problem of fresh black paint not matching 19 year old faded paint which doesnt cost the earth?
Last one....do I need laquer?
Its for my track car and that isnt exactly pretty so I am not looking for a show room finish.
cheers
Ben
swordfish210
new wings dont come as bare metal, they're covered in this black coating (someting to do with electrolyte :unsure: i think) 1 can of primer and 2 cans of paint should do it and yes you will need a laquer
skinner2k3
Do you know if the black has to be rubbed down/off?
1 primer, 2 paint and 1 laquer. Sorted!
djinuk
buy a set of wet n dry (from halfords) make sure you rub the black down with it to give the paint a key to stick to mate
ross009
where can you buy new wings from do the have indicator holes already cut in?
swordfish210
Auto Panels Westers is where i got my new wing from, it had the hole cut in it for the indicator
pugman211
dont wet dry it. if ur gonna do it like that do this:
1 x red scotch pad, rub the whole panel so its full of small scratches.
1 x can of primer. 2 even medium coats making sure the 2nd coat covers everything. let that dry and rub it down again.
clean the panel to prevent as much dirt as u can
1 x can of colour for black, (will cover really well). same thing as primer, 2 nice even coats. let them dry in between coats.
should get away with 1 can of lacquer (clear) same thing as colour, 2 nice even coats should do it. only way around the colour difference is to polish the next panel so it looks a bit shinyier. If all else fails get a GB sticker! lol :unsure:
Will probably look really dull, but if u leave it till next day, and machine polish it will get a bit shinyier
