boldy205
Xu10 Engine Variants.
boldy205
Hi, i have just been to the scrap yard and found a 406 with what looks like a gti6 engine. Are there differant engines that look the same/have diffarant power etc? Thanks
Matt.
The 406 2.0 16v is only about 135hp.
johnrobertgordon
its the same engine as the gti6. Has a different head and cams, inlet manifold is also different. All the gti6 parts will swap straight over.
danpug
Its also an engine that will be pretty nippy/torquey in a 205. Don't get too hung up on a gti6, especially if you can get that engine for a good price.
boldy205
ok thanks. my friend did tell me this but just wanted to check as i did get rather excited when i thought i found a GTI6!!!! (sad eh!!) :unsure: have had the trapdoor sump from it (for my MI), there was also a plate covering the crank(a windage tray??) whats this for / is it benifitial to me??
