BackStreetRacecars
309 Front End
BackStreetRacecars
I have the front subframe and arms from a 309 gti fitted to my 205.. has anyone in compitition used this set up and used different tracking settings?? 205 seems really skittish... obviously the tracking has been changed from when the 205 stuff was on it but wondered if there was any better settings?? any help would be glorious!!
All Praise The GTI
i had the front and rear 309 gti setup(not front arb tho) and it handled amazingly. was arfull at first because tracking was miles out so i had it set to neutral. then it was like it was on rails!
hope this helps
Set the tracking parallel (ie zero toe) and it should all be fine - it'll tramline a little more on rutted roads (usually the inside lane of motorways) because of the increased camber, but the increased grip and reduced wear on the outer edge of the tires is worth it.
BackStreetRacecars
noice one... cheers!!!
