fencer 0 Posted September 4, 2007 I bought myself a new tailgate trim panel but i have a slight problem now. There is a pice of plastic sticking out of the trim to go into a hole in the tailgate (just above the lock). Every time I push it in, it kepps on poping out, ie pushing the trim about 5mm out. Is this supposed to be fixed with something? Share this post Link to post Share on other sites
GLPoomobile 958 Posted September 4, 2007 Well I'll be darned I've never noticed that plastic 'tag' thing before! Got a spare trim in the kitchen so just had a look and there it is I don't get it though as there is no hole in the tailgate IIRC that it fits in to. I'd be tempted to just grind it off if I were you. Share this post Link to post Share on other sites
Gentrix 2 1 Cars Posted September 4, 2007 (edited) Try whose washers, which holds the Archtrim. andi Edited September 4, 2007 by Gentrix Share this post Link to post Share on other sites
fencer 0 Posted September 4, 2007 Try whose washers, which holds the Archtrim. andi hmmm seems a graeat idea! will give it a try! cheers guys! Share this post Link to post Share on other sites
Edp 67 3 Cars Posted September 9, 2007 gentrix that is a handy little box of trim parts where did you get it? Share this post Link to post Share on other sites
Gentrix 2 1 Cars Posted September 9, 2007 the pictures are not mine, I found the whole story on a french board. But I found this: Share this post Link to post Share on other sites
Redtop 14 2 Cars Posted September 18, 2007 When you fitted it did you slide it into the slots on both sides of the bootlid. I noticed the same when fitting a new one to mine and you have to slide it up each side of the boot. It was tight and when in properly that lug fits into it's hole without a clip required. Share this post Link to post Share on other sites
craig f90 0 Posted September 18, 2007 Sounds like a pin to indicate where it exactly fits on the tailgate. sounds daft, can only go on one way (Or if you fit the clip on the back as shown, it probably be harder to detatch, car washes, theft.) Most moder cas have them on door moulding to locate them. Thinking on it though when i took mine off there was no clip securing it. Dont the badges secure it too? cant remember. craig. Share this post Link to post Share on other sites
