Leon C 1 Posted August 29, 2007 What are the dry weights of the XU series engines available for a conversion into a 205? E.g A typical, standard 1.9 GTi engine weight? Mi16 (1.9 alloy)? Mi16 (2.0 cast iron)? GTi-6? Are these cast or alloy?? Apologies if this has been posted before but I couldn't find anything. Share this post Link to post Share on other sites
28CRAIG 2 Posted August 29, 2007 I am sure there in HERE Share this post Link to post Share on other sites
Sandy 191 Posted August 29, 2007 Official weight for the Alloy Mi16 inc Alternator and flywheel, is 133kg. Iron block Mi16 and GTi6 (Iron block btw), are about 18kg heavier, plus the stupidly large right hand engine mount the GTi6 has, which adds about a further 4kg. Share this post Link to post Share on other sites
Leon C 1 Posted August 29, 2007 Cheers Sandy. This is what i've found so far then: 1.9 8v = 90 kg (could only find 1 post on this! sounds a bit on the light side but still... ) 1.9 alloy Mi16 = 133 kg 2.0 iron Mi16 = 151 kg GTi-6 = 155 kg S16 = 160 kg Any figure on the 1.8 XU? Share this post Link to post Share on other sites
danpug 1 Posted August 29, 2007 (edited) Very similar to the 1.9/1.6 xu's, iirc sandy said the difference was under 5kg. Thats the alloy block 1.8's i'm referring to. Edited August 29, 2007 by danpug Share this post Link to post Share on other sites
28CRAIG 2 Posted August 29, 2007 1.8 xu 16v should be same as alloy block mi give or take a few kg The 8v seems a bit on the light side seen as a mi head is about 10kg heavier and the fly wheel a few kg then heavier liners, oil spray bars i would say about it's about 18kg lighter than a mi engine. The 2.0 mi and s16 should be the same weight. Share this post Link to post Share on other sites
danpug 1 Posted August 29, 2007 (edited) The 1.8 16v is definitely marginally heavier than the 1.9 8v and a fair bit lighter than an mi16, sandy has weighed one. Edited August 29, 2007 by danpug Share this post Link to post Share on other sites
Sandy 191 Posted August 30, 2007 The 1.8 16v is closer to the weight of the 1.9 8v than the Mi16, it's quite different to the Mi16, the internals are a good bit lighter. The 1.9 8v is 119kg with alternator and flywheel. That's an official PSA figure. Share this post Link to post Share on other sites
