Guest SeanGTI Posted August 26, 2007 would a 1.6 gti clutch fit/work on a 1.8 diesel engine?? also i need a guide on how to fit a clutch on a 205 1.8 diesel engine. what do i need? please help this is my work van Share this post Link to post Share on other sites
Richie-Van-GTi 74 2 Cars Posted August 26, 2007 No idea what size clutch the 1.8 diesel uses, if its a 200mm push type clutch then yes a gti clutch will fit. Fitting is exactly the same as a gti clutch, remove shafts, remove box, swap clutch and re-fit. I think there is a full guide on the main site. Share this post Link to post Share on other sites
Guest SeanGTI Posted August 26, 2007 the diesel clutch is 200mm with 18 splines on the clutch plate Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted August 26, 2007 A GTi clutch plate will work but the pressure plate apparently has a different spring rating. Graham. Share this post Link to post Share on other sites
