mmt 15 Posted August 25, 2007 Hi The standard Pug cooling valve(don´t know if it´s the right term!) is open at 82 deg. C. Does anyone know if a valve with lover opening temp is availible? I want a cooler engine on my 205 track car. Thanks Martin Share this post Link to post Share on other sites
Mikey S 29 1 Cars Posted August 25, 2007 Hi The standard Pug cooling valve(don´t know if it´s the right term!) is open at 82 deg. C. Does anyone know if a valve with lover opening temp is availible? I want a cooler engine on my 205 track car. Thanks Martin its called a thermostat. im pretty sure that 82 deg c is the coolest thermostat you can buy. its not coolant temp that will be running massively high, its more likely to be oil temperature when track driving. Share this post Link to post Share on other sites
suth82 0 Posted August 26, 2007 If the car is only for track days, just remove the thermostat completely. And yes, you can get thermostats with lower operating temps. Share this post Link to post Share on other sites
Richie-Van-GTi 74 2 Cars Posted August 26, 2007 Drill a small hole in the thermostat and put it back in, should bring it down by 5 degrees or so. You dont want to run it too cool, its not good for the oil. Share this post Link to post Share on other sites
mmt 15 Posted August 26, 2007 Thanks I´ve heard about drilling a hole before. It makes sense! How big and only one hole? /Martin Share this post Link to post Share on other sites
welshpug 1,671 Posted August 26, 2007 i would leave it as it is, 1338 37 is the 82 degree thermostat. the cooling system is sufficient for most applications if its functioning as intended. Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted August 28, 2007 AFAIK you can get a 75'c thermostat from Skip Brown Cars & they fit this to their conversions. Graham. Share this post Link to post Share on other sites
