Spiky
Suspension, Where From, And What?
Spiky
ok, the rear shock on my car are dead, well almost
and next sunday and for the net 3-4 weeks i have track days booked
so need some new suspension, pretty sharp ish
was thinking for NON coilover GAZ?
they ok?
their price?
any other i should consider?
Spiky
just seen these on the autofive website
13ST020 Bilstein Streetline suspension kit £194.00
seems a good price
Bonzai
iirc the streetline are only something like 10% "better" (dont know the correct term :s) than standard items.
I've got the gaz adjustables with -30mm apex springs, i find them a little crashy on the road, you absolutely have to avoid any pothole, drain cover etc, on track they seem pretty happy for what is essentially a budget setup
peugeot o.e or bilstein sprint line.
Rippthrough
What are your dampers set to?
Mine are comfy.
jtek
had a gaz non coilover set on my 306 and was very impressed with them, got another set on order for the 205, seem fairly well built and and the adjustment seemed to make a difference. gutted i sold the 306 with them on before i found out they would fit the 205 too..
danpug
Buy my Bilstein Grp N rears!! Lol.
Please have a search for the Streetline's just to find out how bad the rear's are
But before anyone can sugest anything we need to know your budget
Spiky
ok never really had a budget
but that comment alone has now put me off
i have seen a comment from you about using OE rears,
i'm quite happy to fit just rears, as this the area which is dodgy
so OE 205 or 306???? if 306 is a perticualy model?
Something that I havn;t done personally but in theory it 's a good idea is to use K6 Peugeot 306 GTi rear dampers as they are a direct fit and uprated over std 205 ones
Spiky
well a friend has some 306 shocks which i'm going to use until i sort out what to use.
miles, for my track car, not spending over 300, what would you suggest??
Maybe the Koni Top Adjustable's as these are about £98.00 each, then the Pug K6 or Koni rear's at £76.00 each (prices from my failing memory) but this get's you above your budget, I;ve never liked the Koni rear's persoanlly but the front's are good. You could use the Bilstein Streetline front's but for a track car nit really that well suited
Spiky
thanks for the advice, when you say pug k6, i not sure what that means, is that the standard 205 gti rear shock?
Edited by Spiky
Spiky
ignore that, i just look further up the post...lol
matt-k
I'd like to know the answer to that too!
Anyone?
matt-k
Me too!!!! Ha
the K6 is fitted to the 306 GTi6, The latest spec damper for them
Spiky
sorry to bring this back up
i have fitted brand new k6 to the rear £77 for the two from pug
as for the fronts, miles can you supply koni fronts?
what coilovers have i got a choice of??
i think 200-250 is my budget for the fronts
