dodsworth_gti
Leaking Oil Cooler
dodsworth_gti
just fitted a mocal oil cooler to my mi16,and it leaks :)
its brand new to,i tightened the oil pipes up to and snadwhich plate as tight as i could,and the sandwhich plate to the block then the filter onto that so i cant understand why its leaking ;)
any tips would be great
thanks
ben
Peetypug
did you use PTFE tape on the threads?
ANDYGON
might need to use a dowty seal in there?
ashley peddle
RTV ;)
dodsworth_gti
RTV????? whats that ash?
M@tt
return to vendor?
Silcone sealant.
