oliver17491 0 Posted August 21, 2007 i just need someone with a 1.6 gti or 1.9 to run out to there car and tell me where the 2 plugs go to comming off the coil there should be a 2 and 3 pin connector thanks oli Share this post Link to post Share on other sites
welshpug 1,666 Posted August 21, 2007 3 pin would be for teh dizzy fly lead, mine doesnt have a 2 pin anywhere near the coil though, further down the loom there is a black plug for the SAD and blue plug for the ECU temp sender though. Share this post Link to post Share on other sites
oliver17491 0 Posted August 21, 2007 i got a black 3 pin one and a white 2 pin one, the 3 pin one is sealed and has green, red and black wireing going into it and the 2 pin one has brown and blue wires going into it, what does the 2 pin conector do? or go to? Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted August 22, 2007 Three pin plug is as WelshPug says, for the dizzy fly lead & the white one with a brown & blue wires possible goes to the reversing light switch plug on the gearbox case near the clutch pedal mechanism. Can you see any numbers on the wires near the white plug? If you see #'s 52 & 53 its the reversing light switch plug. Graham. Share this post Link to post Share on other sites
oliver17491 0 Posted August 23, 2007 would them numbers be on the plug? if so i cant see any. just relised that them to wires the blue and the brown are linked onto the same termanal. them two wires go into 4,1 on the coil driver or what ever it is called Share this post Link to post Share on other sites
