Guest A11YKF Posted August 19, 2007 The passenger electric window won't come down but it will try and go up (although already is) when the switch is pressed. Is this just a problem with the switch or possibly something else happens the same if either switch is pressed (drivers or passengers). Share this post Link to post Share on other sites
Phil H 16 Posted August 20, 2007 replace the switch and see what it does. Share this post Link to post Share on other sites
Ren 0 Posted August 24, 2007 Replace the switch on one side and then if it still doesn't work change it back and put the new switch in the other side. The wiring goes through both switches so if one has stopped working it will stop the other side working as well. Ren Share this post Link to post Share on other sites
