Guest Waynerrr Posted August 17, 2007 When I bought my CTi I did so with the plan to replace the whole roof. The back window is frosted up and has ripped in the heat. The roof itself isn't too bad, just a few very tiny nicks, it's still completely water tight. With that in mind, I don't want to spend the sort of money it takes to replace the whole roof. Is there a way of replacing just the back window? Has anyone done it before? I might be planning on selling it so a cheap fix would be ideal. Share this post Link to post Share on other sites
Super Josh 4 Posted August 17, 2007 I'm not really up on CTis, but I thought that the rear screen just zipped in place? Or is this only on 3rd Party roofs? Maybe Ebay is your friend Josh Share this post Link to post Share on other sites
Miles 331 1 Cars Posted August 17, 2007 Yes you can just replace the back window, It's zipped in at the side's and held on above the boot Share this post Link to post Share on other sites
Guest Waynerrr Posted August 18, 2007 I just spotted that, I think it's velcro. Will have a better look when the rain holds off. Thanks Share this post Link to post Share on other sites
Paintguy 0 Posted August 18, 2007 Yep, having assisted in removing and refitting one lately, I can also confirm that the rear screen portion can be removed by undoing the velcro and zipper around the top and sides. It then hooks under a bar at the bottom, held in place by 6 or 7 bolts. These bars have a reputation for rusting badly, so take care when removing it, as I'm told they are ridiculously priced! Share this post Link to post Share on other sites
steve@cornwall 100 Posted August 18, 2007 (edited) Paintguy said: Yep, having assisted in removing and refitting one lately, I can also confirm that the rear screen portion can be removed by undoing the velcro and zipper around the top and sides. It then hooks under a bar at the bottom, held in place by 6 or 7 bolts. These bars have a reputation for rusting badly, so take care when removing it, as I'm told they are ridiculously priced! This is the bar in question! Access the retaining bolts by removing the parcel shelf, followed by the trim behind it, held on by 3 or 4 press in "poppers" The white plastic bit on the bar is where the self tapping screw holds the corner of the hood in place, so must also be removed. Now its just a case of un zipping the top of the screen from inside and releasing the velcro from the sides of the screen panel to the roof lining.Hopefully the black pvc has not gone brittle, or it may all crack apart If you have a sailmaker or tent / awning maker locally, you may be able to get a piece of clear stitched in, rather than pay around 150 for a new panel. Edited August 18, 2007 by steve@cornwall Share this post Link to post Share on other sites
