Blish10 0 Posted August 15, 2007 Hi Does anyone know where I would be able to find details on all Bosch distributors, specifically degrees of advance at certain rpm? Im having problems and I think I need more advance. My vacuum advance is knackered so a new one of those is definately on the cards but I was wondering if a completely different dizzy would give me better advance at the lower rev range? Any help greatly appreciated Cheers Simon Share this post Link to post Share on other sites
welshpug 1,666 Posted August 15, 2007 you just need to get it rebuilt with a custom curve to suit your application, H&H ignition solutions can do this for you t the same time as a refurb, costs about £40 IIRC. Share this post Link to post Share on other sites
Blish10 0 Posted August 15, 2007 Thanks Welshpug but i was hoping for a cheaper quick fix than that. Cheapo dizzys off egay, sort of thing (£5-£10). Theres a few on there of different part nos. but i wanted to know the degs/rpm of the different numbers before i bid. Or do you think H&H would know that sort of thing if i rang em? Cheers Share this post Link to post Share on other sites
Andrwn8304 0 Posted August 17, 2007 Might be wrong here but I think the advance unit works automaticaly and theres no set range for it at certain rpm's. Autofive has Advance units for 1.6 and 1.9's, I changed mine last year and was a bit fiddly. Share this post Link to post Share on other sites
Blish10 0 Posted August 18, 2007 Yeah i know the vac advance is automatic but im fairly sure that different distributors have different advancement settings, but then my knowledge is fairly limited Share this post Link to post Share on other sites
Mikey S 29 1 Cars Posted August 19, 2007 Yeah i know the vac advance is automatic but im fairly sure that different distributors have different advancement settings, but then my knowledge is fairly limited your on about mechanical advancement. its done by a set of weights inside the dizzy body. your right, different dizzys do have different weight setups. if you have any mods, carbs etc, it maybe benificial to have it suitably setup by a specialist. Share this post Link to post Share on other sites
Blish10 0 Posted August 21, 2007 it maybe benificial to have it suitably setup by a specialist. That sounds expensive Share this post Link to post Share on other sites
welshpug 1,666 Posted August 21, 2007 That sounds expensive bnaah, send it off to the aforementioned H&H, thats exactly what they do, drop em a line and see what they can do for you, youll be surprised at the amount of torque and power that a properly setup dizzy can eek out of an engine. Share this post Link to post Share on other sites
