Gibbo GTI 0 Posted August 14, 2007 Would this silicon hose be suitable for the brake servo? Item: 10MM ID SILICONE VACUUM TUBING Length: 2 Metre Quantity: 1 Availability: In Stock Description: Venair Sport Silicone Hose Vacuum Tubing Suitable for all Coolant Hoses, Washer Tubes, Air Hoses, Vacuum Hoses, Water Hoses, Wire cover & Wire Insulation Longer Lenghts available in our eBay shop up to 50 Metre Lengths We stock 2, 3, 4, 5, 6, 7, 8, 9, 10 & 11mm Vacuum Hose in all 4 Colours Material: VMQ (Vinyl Methyl Quality) Silicone Reinforcement: - Temp Resistance: -60C up to +180 Wall Thickness: 2.5mm Colours: High Gloss Blue, Red, Yellow & Black Share this post Link to post Share on other sites
Mikey S 29 1 Cars Posted August 14, 2007 that hose would probably get sucked flat. better off sticking to the standard braided hose. Share this post Link to post Share on other sites
jackherer 543 Posted August 14, 2007 that hose would probably get sucked flat. better off sticking to the standard braided hose. I've used much thinner walled hose than 2.5mm without problems. And this stuff is specifically vacuum hose so I'm pretty sure it'll be fine. Share this post Link to post Share on other sites
Gibbo GTI 0 Posted August 16, 2007 Thanks for the replies, I ended up joining 2 servo hoses i had. Cheers Share this post Link to post Share on other sites
