driversdomainuk 8 Posted August 13, 2007 Hi Was going to ask where I could go online to get info on Mi16 engine, but may be just as easy if anyone could give me this info here : 1. engine oil capacity 2. coolant capacity also ideally any torque settings required when changing cam belt and tensioners. Many Thanks PS - for an alloy block one, not sure if that makes any difference. Share this post Link to post Share on other sites
jackherer 543 Posted August 13, 2007 Haynes shows 5.3 litres (with filter change) of oil and 7.1 litres of coolant. Both of those figures are for the engine when fitted to a BX, the oil capacity shouldn't change in a 205 but the coolant capacity is going to depend on the configuration of pipework you use so varies from one 205Mi16 to another. Shouldn't be more than 8 litres total though unless it has some particularly creative plumbing... You can get the engine chapter of the 405 Haynes from http://www.205gti.com/downloads/Chapter_02...(incl.MI16).zip Share this post Link to post Share on other sites
driversdomainuk 8 Posted August 13, 2007 Haynes shows 5.3 litres (with filter change) of oil and 7.1 litres of coolant. Both of those figures are for the engine when fitted to a BX, the oil capacity shouldn't change in a 205 but the coolant capacity is going to depend on the configuration of pipework you use so varies from one 205Mi16 to another. Shouldn't be more than 8 litres total though unless it has some particularly creative plumbing... You can get the engine chapter of the 405 Haynes from http://www.205gti.com/downloads/Chapter_02...(incl.MI16).zip great - cheers matey Share this post Link to post Share on other sites
Exile 0 Posted August 13, 2007 http://www.mi16.nl/main.htm Share this post Link to post Share on other sites
