driversdomainuk
Couple Of Questions
driversdomainuk
Hi
Just a couple of unrelated questions I need help with please:
1. BE3 gearbox running a Tran-x plate type diff.......what gear oil should i use?
2. Will the lower engine mount & casing which attaches to the block on the 8v fit the Mi block. I only ask as I have a solid lower engine mount on my 8v engine and it would be good if I could just fit it to the MI block without having to have it pressed in or buy another one.
Cheers.
Richie-Van-GTi
1) I would guess you still use pug oil maybe someone else can confirm
2) mount is a direct fit
driversdomainuk
"2) mount is a direct fit "
Great - and the group N rubber (from BB&M) is stiff enough so the rocker does not knock against M/C..?
driversdomainuk
as far as gear oil goes, I cant find any "performance" oils for 75w-80. However, DT do sell Miller CRX 75W-90
Would this be ok..?
driversdomainuk
So would Miller CRX 75w90 be ok to use with my Tran-x'd BE3 box as the manual suggests 75w90 (with no lsd)
