chris1986 1 Posted August 12, 2007 i have a really strange fault at the mo. the nsf and ns side repeater indicators don't work but the rear and all the others do. it's not the bulbs. just when you switch them on it just clicks fast. but not working the nsf indicator and repeater any one got any ideas??? thanks Share this post Link to post Share on other sites
jackherer 543 Posted August 12, 2007 check the earths (behind the headlights, next to the rad) for corrosion and clean up if needed then do the same to the plugs for the bulbs themselves. Share this post Link to post Share on other sites
brianthemagical 1 Posted August 12, 2007 it definately sounds like the front ns is not working, could be the earth as jack said. just a case3 of testing with a multimeter. how do you know it's not the bulbs? Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted August 14, 2007 You can check if its the earth by runnin a seperate piece of wire from the earth pin of the front indicator plug with it still connected to the battery negative terminal & see if that fixes it. It did on my old white 205 diesel. (lasted until it was scrapped). Graham. Share this post Link to post Share on other sites
