Nathan 0 Posted August 6, 2007 The fuel surge my car suffers from is really annoying, has anyone found a way to cure it (and cornering slower isn't an option!). Anything less than than 1/2 a tank and its really bad, it'll even do it when I've got nearly 3/4 in. 1st option is maybe another pick up in the tank, the 2nd option I was thinking of (which may be slightly easier to fit) would be some kind of small secondary fuel swirl pot/tank has any one made one of these of fitted an off the shelf job? Cheers Share this post Link to post Share on other sites
James_R 3 Posted August 6, 2007 1L swirl pot and low pressure pump to it then high pressure fed off it. Look in the demontheifs catalogue should have everything there. Share this post Link to post Share on other sites
16v205 9 Posted August 6, 2007 You dont need a specific low pressure pump, use the normal 205 gti intank pump to fill the swirl pot. The 205 fuel pump flows 2.16ltr/min and will only build up pressure if the swirl pot overflow outlet pipe is too small in diameter. Small 750cc/1ltr alloy fuel tanks can be had for less than £50 delivered, use a 405 mi16 external fuel pump and thats the big cost saved. A few quid on a relay, fuse holder, 30amp wire, fuel hoses and proper fuel clips and you can fit a complete surge tank kit for less than £80 all in! Mines been running for a few years now and cost a similar amount. Rich Share this post Link to post Share on other sites
philfingers 5 Posted August 18, 2007 Mine used to surge below 1/2 tank. I took it out, cleaned the s*ite out of the bottom of it and it was fine after that. Must have been the muck or maybe a crushed pipe or something. Worth a try for nothing! Share this post Link to post Share on other sites
Bally 4 Posted August 18, 2007 usually the little plastic pot in the bottom of the tank has broken away and moved cause its only plastic welded there. Had that sanme problem, changed the tank and I can go right down to gas light on and corner any where with no surge Share this post Link to post Share on other sites
ORB 227 1 Cars Posted August 18, 2007 You could try running with a full tank Share this post Link to post Share on other sites
Stonesie 0 Posted August 18, 2007 pffft more weight?? i would go with the swirl pot and 2nd fuel pump myself.... Share this post Link to post Share on other sites
Stonesie 0 Posted August 18, 2007 woah no edit option....... anyway i forgot to say i had the same issue on a nova (dont hurt me please) that i bought as a 1.4L after fitting the 1.6 GT/E engine on K-jetronic using a 2.0 astra (ashtray) pump outside the carb tank, back then i was young and stupid and didnt eaven know what a swirl pot was..... Share this post Link to post Share on other sites
Rob Thomson 6 Posted August 19, 2007 I'm sure I read somewhere that the later tanks are better baffled than the older ones. For what it's worth, I have no problems with my 1992 1.6, whereas my 1989 309 (which I assume has a similar tank) was a complete bastard for surge below half-a-tank. Share this post Link to post Share on other sites
petert 616 Posted August 19, 2007 I chop the tank in half and get it plastic welded back up. Less surge, less fuel, less Kg, less money. Do a search and you'll find a picture I posted some time ago. Share this post Link to post Share on other sites
Normski 1 Posted August 22, 2007 I'm sure I read somewhere that the later tanks are better baffled than the older ones. For what it's worth, I have no problems with my 1992 1.6, whereas my 1989 309 (which I assume has a similar tank) was a complete bastard for surge below half-a-tank. My track 205 (1992, 1.9) has no problems with surge even with slicks and the fuel light on. So there's maybe something in that ^^. Share this post Link to post Share on other sites
Bally 4 Posted August 23, 2007 usually the little plastic pot in the bottom of the tank has broken away and moved cause its only plastic welded there. Had that sanme problem, changed the tank and I can go right down to gas light on and corner any where with no surge Did you all ralise what i said here. It is worth a check at least in the tank. Take out the pump and see if the little cup has moved Share this post Link to post Share on other sites
